Anyone Recommend of a Good Cab Cover?
Old 05-09-2009 | 08:16 AM
deadspot's Avatar
While on the topic - for those with the bestop - it fits over the softtop when it's down correct? seems like a lot of bulk in the back when the top is down - it fits over all of that? Thanks.
Old 05-09-2009 | 08:33 PM
paramaniac's Avatar
it does, i dont think you can fit the tabs under the rail (like the sail panels do) but there are straps with clips that hook under the tail gate that will hold the rear portion in place
Old 05-11-2009 | 07:37 PM
I think you should be able to adjust the Trail Cover around mirrors mounted in the hinges, but it will leave a slight gap there that water could get into. However, I have used my Trail Cover with the factory doors and mirrors on, and there's enough slack there to permit it to be secured to the bottom of the Jeep (it uses plastic clips that slip over the bottom pinch seam). In that case, there's a large gap at the front of the Trail Cover on each side, but it's not a problem since the doors will keep water out.
__
Thanks, I am not sure what cover to use. I will do more research.________________
Old 05-11-2009 | 07:53 PM
Rebel Heart's Avatar
Default Best Quick Cover?
I am going to take the hard top off for the summer using tube doors. But I need a top to cover for elements when at work. I found several at Quadratec: Bestop All Weather Trail Cover, Noah Quick Cover and WeatherShield Quick Cover. Any suggestions? The Bestop is the least expensive w/ WeatherShield the most. I want one that is easy to install, lightweight to work with.
Old 05-11-2009 | 09:09 PM
paramaniac's Avatar
trail cover.... definitely
Old 05-12-2009 | 04:05 AM
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
X2, although I wouldn't call it "lightweight." It's a similar weight fabric as the softtop. Takes about 2-3 minutes to put on and take off. It comes in a storage bag, and I still have a standing offer to buy a steak dinner for anyone who posts a video of successfully fitting it back into that bag. LOL.
Old 05-12-2009 | 04:08 AM
greenamphibious's Avatar
X3 and it keeps fuggin stray cats from pissing in your Jeep at night
Old 05-12-2009 | 08:07 AM
KarenS's Avatar
THANK YOU. i am not the only one that the dang stray cats jump in and spray.
Old 05-12-2009 | 08:08 AM
KarenS's Avatar
I think the bag is for the cats. cause it's not fitting back
Old 05-12-2009 | 08:16 AM
Appreciate the replies. I won't even try to put it back in the bag......
