Anyone Recommend of a Good Cab Cover?
Quick Cover
Love having the roof down but tired of dealing with the softtop. I'm thinking of buying a quick cover (either Bestop All Weather or Coversraft Weathershield). Anyone that has one have an opinion? Thanks for your help
I have the smittybuilt cab cover. It was cheap, and suprisingly it actually works pretty good. However, it doesnt really fit well if the doors are still on. It still goes on and does its job, but its more of a pain in the butt.
Cover
I have the Best Top trail cover and it works great. It fits tight and one person can put it on in no time. There was one time last summer during a hard rain overnight it did puddle over the drivers seat but it didn't leak. I use it all the time.
X3 for Bestop Trail Cover. I even use it with the safari top, Duster and Windjammer, though it doesn't slip into the lip around the trunk area properly when the Duster is installed. Still works to keep most water out. Biggest problem is without the safari top, the Trail Cover under heavy rains can sag in the middles (front/rear seats). I have to crawl inside and push up to get that water off of there, sometimes introducing a stream of water into the Jeep through the raised Trail Cover edges. But, I'm happy with it. It even survives very severe weather (something that my hood did not):
I don't remove the doors since it's the wifes Jk and she takes the grandaughter and her friends, so the doors stay on.
The Mopar cover is easy to throw on and protects the Jk pretty good against those sudden downpours in the summer when we have the soft top removed.
Of course we also have the Bestop trail duster, and that stays on all summer when the top is removed.
I think you should be able to adjust the Trail Cover around mirrors mounted in the hinges, but it will leave a slight gap there that water could get into. However, I have used my Trail Cover with the factory doors and mirrors on, and there's enough slack there to permit it to be secured to the bottom of the Jeep (it uses plastic clips that slip over the bottom pinch seam). In that case, there's a large gap at the front of the Trail Cover on each side, but it's not a problem since the doors will keep water out.
