Any fix for a back bow soft top leak?
Just got back from the dealer and they tell me there is nothing they can do about it.
Within 2 weeks they asked me to call them to see if anybody else has this problem.
Because it is the first they see.
Mine leaks at the back bow all along the seams all the white tape gets wet and then it also leaks on the frame.
Anybody else have this problem and how did you resolve it?
but !! they say ,rear seam cant fix ! its just the way jeeps are from the factory !
they got me to order roof repelant stuff for helpinh the issue can spray it on any part of the roof to help with seams ,however . wont cure it , and they say that if i put marine type silicone over the inside weat i see it leak and where i see it weeping , it will void warrenty on roof all togeather, so it appears im suposed to sit back and watch it drip so i can have a warrenty on my roof against leaks , but yet theres no way to repair the leaky seam they know of yet! lol
that blows my mind ! its not the service guys fault he just follows what chrysler says !!! ill tell u what my plan is!!!! i own my veihcle and its 2011 and if the spray dosent work and it continues to leak ,and they cant fix the dam thing! Then i will void my roof warrenty very soon cuz i aim to go over the inner roof seams with gorilla duct tape!!!! ill wait till weather gets better and ill stop the bastard from leakin myself if i have to seal the whole dam inside of the jeep with gorila duct till it cant leak!! they say that stuff is good under water for 8 years! so it certainly will seal up the cheap tape that comes from the factory , it looks like bandage tape they use in hospital when they bandage you up after you up and put a little tape to hold the gauze pads ! its white, and its saturated and drips down just as if you went home and put your bandage in water , obviously the tape isnt holding the water back , so its not good tape but gorila is awsome !! just my idea, and if the front leaks again ill wrap the whoe frican jeep in gorilla till it cant get inside ill seal the doors closed and climb in from the rear window
, there thought is silicone might discolor the upper black roof and then it voids warrenty ,duct tape that keeps the water from dripping down and all over the rear floor, and getting carpets and my gear wet is my over all concern ! what the roof does between the duct tape and the outside of roof i could care less about duct tape on the inside it will send the water back up to where ever its comming in and be on the outside instead of in!!! hope i made sence !
![Synister](https://www.jk-forum.com/forums/images/smilies/synister.gif)
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
![eek 2](https://www.jk-forum.com/forums/images/smilies/sSc_eek2.gif)
![Wink](https://www.jk-forum.com/forums/images/smilies/wink1.gif)
![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
is there , if thats what were paying for
![Brows](https://www.jk-forum.com/forums/images/smilies/brows.gif)
ill be honest i was thinking of buying a rubicon as well at some point but if they cant take care of stuff right im going to put my money elsewhere not with chrysler! had to get that off my chest !! i feel better , temporary im sure !
![Question](https://www.jk-forum.com/forums/images/smilies/question.gif)
What you said jeepmojo (by the way your pm box is full I answered you back)
is almost exactly what they told me.
strange that there is still a problem with the leak .![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
Well
I will try another dealer if it is the same crap,I will try silicone and duct tape also.
Seems that it has worked for others.
Well
still drips !ill have to fix this one myself too and to hell with chryslers so called warrenty ! theres no such thing if you ask me !
![sad2](https://www.jk-forum.com/forums/images/smilies/grayno.gif)
