5 wheel rotation
The mud terrains wear more unevenly, specially in the jeep. But going every 3k is overkill IMHO, on the other hand you can't over rotate them and it would be a little more pleasant on the ears for those first few hundred miles.
There is no reason whatsoever to not rotate the spare in when it is full sized other than being lazy. Putting a full sized tire on the same axle as a worn down tire (specially when it is 32") is going to cause unnecessary wear on differential, and potentially be unsafe. Don't believe that? Go ask a tire dealer to install one new tire, they won't unless they shave it down to similar diameter. They will put two new tires on the back, that is it.
Rotate the 5th in because otherwise it might as well be a doughnut spare.
