4door - Rear seat removal?? How to...
just curious... i have already pulled my carpet and plan on doing a test run of the duplicolor roll on bedliner this weekend. I am just going to do the rear and if it turns out okay then i will do the rest.
How do you remove the rear seats and brackets? I counted about 10 bolts that seemingly need to come out... but just want to make sure i am not missing some hidden "quick detach" feature.
Thanks in advance!
Thanks in advance!
HA, just take out the bolts. No quick fix. Take out the lower ones in the floor under the seat and the seat will flip up. Then you can get to some of the others much easier. Once out I like to put the bolts or nuts back on the studs or holes so as to not loose any of the hardware. Its not hard at all. I am getting my bedliner put in next week. Be sure to show pictures when you are done.
Jeff
Jeff
Thanks in advance!
Thanks in advance!
Na, I did it by my self. They are a two section thing. The two on the passenger side and the one little one on the drivers side. It will make more sense once you get started. Nothing to it. Have fun.
I put just the little seat back in to take my daughters to a pool party and had to bolt a seat belt buckle to the floor and it worked perfect. Quick and easy.
Jeff
Jeff
