400 miles per tank!
Old 11-11-2007, 08:54 AM
  #31
Embalmer's Avatar
seems as of late id be doing good if I can hit over 200 mpt.... damn cold weather
Old 11-11-2007, 09:46 AM
  #32
justinstoffregen's Avatar
Am i correct in assuming that if you have tires over 33" that the mpg on your computer or what you've calculated in your head the old fashioned way is incorrect unless you've had your rpms calibrated? That would make a lot of these posts invalid Anyone know the answer?
Old 11-11-2007, 01:54 PM
  #33
JK-KJ's Avatar
That shouldn't make a difference....if I drive 300 miles and it takes 15 gallons to fill the tank back up, that's 20MPG....I don't see where the tire size/gears would matter. If it takes 15 gallons to drive 300 miles, it takes 15 gallons to drive 300 miles...regardless of tire size.
Old 11-11-2007, 02:41 PM
  #34
Dr.McNinja's Avatar
Yeah, but if you are basing it on your trip meter, then it may say that you've gone a certain distance when actually you've gone a different amount.
If you are basing it on GPS data, or something else, then yeah, the accuracy is the same.
Old 11-11-2007, 02:53 PM
  #35
JK-KJ's Avatar
How much of a difference would it be? Probably not enough to matter.
Old 11-11-2007, 03:20 PM
  #36
Exclamation
def. makes a difference. Check out this guys formula. search for the thread below:
Larger tires = more miles indicated?
Dr.Mc ninja is right. If you are basing the information on incorrect data then you have useless info. Try multiplying your mileage by 1.187 to see your real mileage. Obviously disregard this if you are using gps.
Old 11-11-2007, 03:29 PM
  #37
JK-KJ's Avatar
I know that there is a small difference, but it's not enough to worry about unless you're running 35's or larger....and if you've got tires that big, you're obviously not worried about MPG anyway.
Old 11-11-2007, 05:12 PM
  #38
just trying to be accurate for those who want knowledge.
Old 11-11-2007, 06:23 PM
  #39
HEK
HEK's Avatar
I can't tell you for sure what my gas milage per tank is as I don't let it get below 1/2 tank.....I average 19 to 21 depending on the type of week I have...leaving a few minutes late makes me put the pedal to the metal...or leaving early makes me just cruisse and let the school bus in front of me stop an d go as I just slow down...so BTW how many gallons did you use in your 400 mile trek??...
Old 11-12-2007, 11:25 AM
  #40
Thumbs down
I have been getting 11.43 miles per gallon personally.
Quick Reply: 400 miles per tank!
