400 miles per tank!
That is pretty amazing. I thought I was getting pretty good mileage at around 20-21mpg consistently overall. The most I've seen on my trip meter is about 315 (when the fuel light comes on).
I'm running a bone stock X, 23S package, 255/75R17 tires - which I believe are the biggest you can get stock.
I grabbed a couple of cell phone pics before I filled up this morning. Unfortunately I was not able to get both in the same pic without it being too blurry to read.
Here's the first one showing 406.9 miles. I reset the trip odometer each time I fill up.
Here's the second showing the estimated mpg, as calculated by the computer:
The computer is a little off because it took 18.374 gallons to fill. 406.9 miles / 18.374 gallons = 22.145 mpg
I gotta say I'm pretty happy with that.
He has an Unlimited which has a larger fuel tank. I bet you'd get 400 if you had his tank with your mileage too.
Maybe I just overlooked it.....But, I did not notice!!! ...What trans and gears do you have?????????????
Neutral is Neutral and has no effect on your clutch as long as you are not riding the pedal, and the same goes for your torque converter in the a-matic.
