4.10 Gears?
After exhausting every possibility the dealer had me ride with their master tech. He said there really is not much he can do and that this is the nature of the lock up TC and the four speed 42RLE tranny. He has reset the software but after it learns my driving habits it always comes back after 500 miles or so.
You'd be screaming with 5.13s. You'd be about 2600 RPM at 70 MPH in overdrive -- 3800 RPM out of overdrive!
It sounds like you might benefit from a programer that will let you reprogram the transmission shift points.
http://www.quadratec.com/products/17614_5001.htm
You shouldn't need the programmer, because you'll still be using factory specified tire and gear sizes. The service department at your dealership can program the tire size and gear ratio for you.
I believe the gears will help you quite a bit.
Thanks so much for all your help. So even going from 3.73 to 4.10 you think it will help?
Look at the formulas and plug in the numbers. The best performance I've had with the Jeep is my current setup which is 35's and 5.13's because it puts me at 2600 going down the freeway at 75. The stock was 2250 which is too low. I would NOT waste my money on ANY gear change that results in less than 2500 rpm on the freeway. This little engine is happiest above 2500 and you want to stay below 3000 for fuel economy reasons.
3.73 to 4.10 wouldn't be worth the money. Do I recall that you're staying with 32's? If so it is my contention that Jeep Misgeared the stock Rubi with 4.10's and 32's. They should have done 4.56's.
Look into 4.56's; that would be worth the money - as long as you are going to stay with 32's. If you plan on going larger you'll have to rethink things.
Unfortunately the Jeep dealer doesn't offer anything larger than 4.10 if you're worried about your warranty. Find a good 4x4 shop that does a lot of gears. Dealers don't do enough to get good at them.
As far as reprogramming your speedo the dealer can't go beyond 4.10's and 32's. You have to do that yourself with a Hypertech Speedo Calibrator which costs 200.00. I don't thinink it can be used on more than one vehicle. I bit the bullet and bought one so the shift points would be brought back to where they should be.
