2500 miles and troubles 😖
Got my jk in June (first car I have bought) and already the check engine light has been on twice. First time on 8/8 the dealer chalked it up to being a "loose gas cap". It just went off 3 days ago and now it is back on again. Checked the gas cap. And it defiantly isn't loose. Any ideas?
It's a 2015 jk, new only 2.5k miles. 😕
What does the error say? Only check engine? My 2012 once had a loose gas cap error. This was actually caused by a tiny air leak in the hose going into the Evap canister. I tweaked the hose, the light went out and never returned.
If the check engine light is on, a code has been set. The shop should be able to scan it to figure out what it is. It's a brand new vehicle. Don't monkey around. Make it the dealer's problem, because it should be.
Once you get a few bugs worked out, your Jeep should deliver many faithful miles of trouble-free performance. At least, that's been my experience with owning 2 of these things. Good luck!
hopefully I don't get in trouble for posting links to different sites, can't remember what is allowed and what isn't, but follow the steps outlined here to read your own engine code, then write it down, and Google the code to find out what it means and how to fix it, then go to the dealer armed with knowledge of what is actually wrong with the Jeep so they can't monkey you around as easily.
Project-JK.com - Jeep JK Wrangler Resource » Jeep JK Wrangler Diagnostic Trouble Codes DTC How to Check Them
Happy Jeeping!
Happy Jeeping!
hopefully I don't get in trouble for posting links to different sites, can't remember what is allowed and what isn't, but follow the steps outlined here to read your own engine code, then write it down, and Google the code to find out what it means and how to fix it, then go to the dealer armed with knowledge of what is actually wrong with the Jeep so they can't monkey you around as easily. Project-JK.com - Jeep JK Wrangler Resource » Jeep JK Wrangler Diagnostic Trouble Codes DTC How to Check Them Happy Jeeping!
Happy Jeeping!
Do a search for elm327 scanner. Then get a cheap app on your phone or iPad such as Dashcommand. Then you can see all kinds of stuff, including trouble codes. Total investment under $30.
