2013 jk sport vs 2013 toyota tocoma
It was a steep Hill climb with dirt/rocks/roots. It was a little slick out. Since it had rained a couple days before.
I have a 2013 jk sport auto with 3:73 gearing with following mods: terra flex leveling kit & quick disconnects, 265/75/16 terra grapplers. Front bumper and rock rails.
I had the sway bar disconnected, tires were at about 30ish psi, I had it in 4wheel low, and had the auto slapped into 1st gear. I climb pretty slow and steady....
Maybe more speed?
Maybe it would have helped to have the trac control on? To help with wheel spin? So maybe 4w high?
Can you add trac control in 4wl?
Maybe more speed?
Here's my take: 12 to 17 psi will get the traction way up, that's probably all that was needed. How low to go depends on how stiff the tires are, how large the tires are, rim size, weight, terrain, etc. Temperature affects how stiff tires are, so I'll air down more when it's colder. For me, typically about 1" of height decrease from normal pressure gives about the right amount of extra tread on the ground. But at 30 psi, I doubt there was any measurable change.
Slow and steady in 4LO would be my preference with the terrain described. As you know, using speed and momentum can work, or it can damage something.
Unless it is an Auburn Ected, which I have on my front axle ...
http://www.fourwheeler.com/how-to/tr...-differential/
I had a 2011 Tacoma with all the bells n whistles. I went every place my buddies with Rubicons went so long as I didn't get high centered. The ATRAC on the Tacoma which uses the ABS system to apply power to spinning wheels works very well if you know how to use it properly.
So he has a limited slip (good) that locks on command (awesome) and you have an open dif (not so good) and you need to air down more...like16-18psi
Either way hes got locker on ya.
I dont always drive where others cant. but when I do, its in my Jeep. Stay muddy my friends
Here's a good Chrysler write-up on the Jeeps brake traction control: Chrysler Blog - Jeep Brake Traction Control Explained
Thank for all the help guys. Lots of good info.
Turns out he doesn't have a rear locker, the selectable switch he was talking about was a traction control button. Ha!
So now a question about the Brake Lock Diff after reading that awesome article on it.
I'm surprised I have not seen it work or even felt it engage.
I'm guessing that I'm not driving the jeep right and giving it a chance to let the BLD work. Anytime I felt a slip and tires started to spin, I would stop, and try again and again. After reading that article, it mentioned you have to keep on the gas when there is wheel spin to let the system know it has to work. I don't think I ever did that. I would immediately let off the gas, hit the brake, reverse, and try again.
So any advise for learning how to better use the BLD? Driving style?
Do you guys with autos, use the slap stick and select gears in 4L? Or just keep it in Drive?
https://www.youtube.com/watch?v=Hv2DKDinfj0
