2012 Pentastar - not the torque we had hoped for....
#61
I'm sure there will be aftermarket mods and tunes that will make it a player. Look at what some of the diesel pickups are getting for power after they're modded, it's a whole heck of a lot more than putting a superchip and exhaust on a 3.8 and pretending it made a difference.
#62
If the pentastar eventually gets direct injection, unless there is forced induction in combination with the direct injection, you will not gain ANY power compared to the non-DI version of the pentastar. The reason is that any non-DI gasoline engine is already running as close to a nearly stoichiometric ratio as possible (to not only run properly but because it maximizes power by using all of the available oxygen in the cylinder AND it allows the three-way catalytic converters required for emissions laws to function properly).
Even if the pentastar gets forced induction I would not chip it as a direct-injection diesel and a direct-injection gasoline engine are VERY different animals. The direct injection diesel engines ignite the fuel based on ONLY the heat in the cylinder (basically as soon as the diesel fuel is heated to the temperatures at TDC in the cylinder and makes contact with oxygen, the diesel fuel auto-ignites). The overall stoichiometry of a direct-injected gasoline engine is extremely lean just like a diesel (allowing better fuel economy than the non-DI version of the same engine) but a direct-injection gasoline engine still requires a spark plug to ignite the fuel. In order to reliably ignite the direct-injected gasoline spray however, the spark plug placement is EXTREMELY important because it has to be far enough away from the end of the injector to allow oxygen to mix with the fuel before the ignition source (to allow ignition to occur reliably) BUT it must also be close enough that the fuel spray that it is not locally too lean at the spark plug (that would not allow ignition to occur reliably). If you change the amount of injected fuel into a direct-injected gasoline engine with forced induction you might be able to increase the power output of the engine with a chip, but you also change the geometry of the fuel spray in the cylinder. This in turn would compromise the reliability of ignition along with a bunch of other unwanted side-effects (such as fuel wetting the cylinder walls and being washed down into the engine oil, etc).
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
#63
So sick of hearing about bugs in the new engine. By the time the JK comes out, the engine will have been in the GC for a year.
People overthink and over justify shit on the internet.
#64
#65
Want the diesel!
#66
Hi from Sweden in Europe.
Many are talking about diesels engine in a wrangler but a talked to two dealers in Sweden and the say that in Sweden a diesel wrangler is about 11000 USD more than the petrol wrangler.
Addition to that we have a diesel tax that cost about 1000 dollar a year.
it maybe nice with diesel but in Sweden I do not think its a wice choice concidering the extrem cost.
In US a wrangler sport petrol 2 door cost about 22 000 dollars.
In Germany a Wrangler sport diesel 2 door cost about 37 374 USD and a petrol cost about 35 000 USD, not so big difference compared to Sweden prices, much higher diesel engine costs.
http://www3.jeep.de/pdf/specs/jeep_w...und_preise.pdf
Anyway, I have the Suzuki Jimny a really good 4wd, cost about half price and takes about half gazoline compared to the wrangler but is a old model and Suzuki do not seem to want to refine this excellent car so I will probably buy a wrangler with the pentastar. The Jimny I have is from 2001 and lacks ESP, antispin etc and will easely flip over so they do not sell it anymore in Sweden. It have the same 4WD system as wrangler but no traction control etc. Soon I need a new 4wd and 2 door car.
Can I afford a wrangler in Europe? the taxes would probably be very high because the engine is so big, My Jimny is only a 1.3 liter engine and can go almost anyware because it is so light.
The cost for the Jimny was about 1770 USD in Sweden, but if it would be sold in US the cost would probably be around 1300 USD.
I am a nature photographer and need 4WD and ground clearance, my photos
http://www.pbase.com/omar_brannstrom
Jimny and a wrangler
![](http://data.motor-talk.de/data/galleries/0/16/2718/9340836/jimny-2-67220.jpg)
http://data.motor-talk.de/data/galle...ny-2-67220.jpg
Here is a non stock Jimny in action.
http://www.youtube.com/watch?v=FUBMX_SlKVM
http://www.youtube.com/watch?v=N5EeUsyEJJc&NR=1
http://www.youtube.com/watch?v=X5e899eOSNs&feature=fvst
http://www.youtube.com/watch?v=lL4mo...eature=related
Best regards from Sweden
Omar Brännström
Omar Brännström
#67
I think that you missed his point about it not being a 1st year engine. Reread his post.
#68
#69
very true... my wifes 2.5 l turbo subaru forester out performs my jeep on multiple levels. except for a few on offroad capability.
#70
Undoubtedly, the 5 speed auto would make a huge difference on the 3.8l, making it on par with the manual transmission. Same with the higher stall speed converter.
Definitely some fancy engineering footwork to hit above 90% peak torque at 2,000 rpm. The downside is the dramatic fall off under 2k. While differential gear sets aren't going to need to be as steep for on road driving, my guess is we'll be seeing a lot more talk about transfer case upgrades for off-road use.
Hopefully we get a Rubicrawler type product soon for the new auto transmissions, as I believe it would make a very nice combination with the auto transmission, stock 4.10s and up to 35" tires.
