2-Door Towing
2-Door Towing
I need some opinions... I am planning on getting a 12'X6' van trailer to move my apartment with. Is my 2 door rubicon capable of towing something this size loaded down?
you should be able to, i have seen X's towing dual trailed jet skis and that, also an unlimited sahara pulling a 20 or so foot long crownline boat, you might have to hit the brakes a bit harder and push the gas a bit further but thats with most vehicles anyway if they are loaded down. what gears are you running?
I have a 2dr and have pulled a trailer that size, got it weight and it was 4200 lbs. I do not recomend that much wieght but I only went 3 miles. I pull a 20 ft crownline every so often but its only 20- 30 miles. It does a descent job but braking takes longer and don't take corners to fast. P.S. the boat and trailer is 3100 lbs max.
