Trailmaster adjustable control arms - full set with bolt kit
Hey guys,
I'm selling a full set of adjustable Trailmaster control arms. I had these on my rig for about 18 months, but I wanted to switch to control arms that had a bend so I could get rid of my spacers. The Trailmaster control arms use Rock Krawler 2nd generation flex joints. The flex joints have been newly rebuilt (as in 0 miles on them), and grease fittings have been added instead of the original cap bolts for better maintenance.. The arms themselves are in good shape. One of the rear lower arms has some enamel sprayed where the original coating had been chipped. One of the rear lower arms has two small grooves that had been ground in very slightly in order to allow tightening/untightening of the joint. It also has enamel sprayed to protect the coating.
I'm also including a full suspension bolt kit. The bolt kits that I've seen for sale only include bolts for the front end, but this kit includes bolts for front and rear control arms, front and rear trackbars, and shocks. The bolts are grade 8 and the nuts are all stover locknuts. The actual parts list can be seen below.
Please PM me if you're interested. I'm asking $800 shipped for the arms and bolts (essentially 650 for arms, 100 for bolts, and 50 for shipping).
Full kit:
Control arms:
Closeups on arm with ground wrench fitting:
Bolt kit:
Bolt kit parts list:
Bolt kit application notes:
Full kit:
Control arms:
Bolt kit:
It's for the 4.5" lift. There's a lot of adjustment in the arms - I think it would accomodate about any size lift with the arms in the stock frame side brackets.
Micah
Micah
