JK 4.5" 5.5" Rubicon Express LONG ARM KIT + Montube kit & Drive Shafts
SOLD
Jeep Wrangler Unlimited 4 door JK - 2007 to 2009
4.5" Rubicon Express EXTREME DUTY LONG ARM SYSTEM - kit
If you are local, I have a friend who can professionally install it for a reasonable price.
+ Montube shock kit and front and rear CV Yoke Drive shafts.
(this kit can be a 5.5" Jeep Unlimited kit with spacers for +$90, it is also the 5.5" for the 2 door)
THIS IS THE BEST LIFT KIT FOR YOUR JK, IT IS THE ONLY LONG ARM RADIUS KIT ON THE MARKET.
Complete with no missing parts
Part #RE7344 lift kit - Valued at $3300
rubiconexpress.com/Products.aspx?Cn=369&Pn=3547&XnPath=173,352,353,36 9&Vid=AD2FBB513684
and Part #SK010904RXJ monotube kit - valued at $320
rubiconexpress.com/Products.aspx?Cn=367&Pn=3550&XnPath=173,352,355,36 7&Vid=AD2FBB513684
both front and rear CV YOKE DRIVE SHAFTS - valued at $700
rubiconexpress.com/Products.aspx?Cn=360&Pn=3465&XnPath=173,352,358,36 0&Vid=1F70E7513691
rubiconexpress.com/Products.aspx?Cn=360&Pn=3498&XnPath=173,352,358,36 0&Vid=1F70E7513691
Front T-case yoke - valued at $75
rubiconexpress.com/Products.aspx?Cn=360&Pn=3475&XnPath=173,352,358,36 0&Vid=1F70E7513691
Rear T-case flange - valued at $68
rubiconexpress.com/Products.aspx?Cn=360&Pn=3474&XnPath=173,352,358,36 0&Vid=1F70E7513691
This kit is for the 4 door, but to my knowledge, if you have a 2 door, you can exchange the rear control arms and rear drive shaft with rubicon express.
For the 2 door, you can still use the same springs, but it would then be a 5.5" lift.
This kit is valued over $4500 before taxes and shipping.
After shipping and taxes, I have over $5000 into this kit.
Yours for $3150 shipped within 48 states. Or $2900 local pick up. (Gig Harbor, WA)
I can accept paypal
feel free to reach me at my cell 253-228-7463 -erik
System contains-
RE1372 Front 4.5” Coil Springs (5.5" for 2 door)
RE1377 Rear 4.5” Coil Springs (5.5" for 2 door)
RE1157 Sway Bar End Links
RE1143 Gen2 Sway Bar Disconnects
RE1380 2” Front lower bump stops
RE1387 Rear bump stop pad
RE1530 Front SS brake line set
RE1540 Rear SS brake line set
RE1605 Rear Track Bar Bracket
RE1675 Front Extreme Duty Track Bar
RE1680 Front Extreme Duty Drop Track Bar Bracket
RE4070 Extreme Duty Control Arm Front Lower Left
RE4080 Extreme Duty Control Arm Front Lower Right
RE4075 (2) Extreme Duty Control Arm Front Upper
RE4085 Extreme Duty Control Arm Rear Lower Left
RE4095 Extreme Duty Control Arm Rear Lower Right
RE4090 (2) Extreme Duty Control Arm Rear Upper
RE4520 3 Piece Extreme Duty Cross Member
RE4525 Rear Control Arm Bracket kit
SK010904RXJ 4.5" RE MONOTUBE KIT
RE1883-365 FRONT 1310 CVO DRIVESHAFT
RE1887-430 REAR 1310 CVF DRIVESHAFT 4DOOR
RE1805 REAR T-CASE FLANGE ADAPTER
RE1810 FRONT T-CASE YOKE
I took pictures of the driveshafts since the rubicon express site dose not.
[/QUOTE]
I can accept paypal
System contains-
[/QUOTE]
Last edited by confusedYJTJ; 01-10-2009 at 01:58 PM. Reason: please don't post clickable links to non sponsors
