Zoglmann's Build Thread
Old 09-29-2013, 09:39 PM
  #51
Zoglmann's Avatar
Started my truss this weekend and the jeep is still a apart. Having issues with my tig. Next weekend it will be getting the truss finished, rc lca's, bullydog gt, fresh Bedliner in spots and paint on some accent peices. Possibly a good buff job as well lol
Old 09-30-2013, 03:56 AM
  #52
Jersey_Devil's Avatar
One of these days I'll get mine on.... Had it sitting around for a year now! Lol
Good luck with ur tig
Old 09-30-2013, 03:36 PM
  #53
Zoglmann's Avatar
Probably gonna go buy a mig this Friday and blow the truss on it. And you gotta get that thing on there! I fit the whole thing and it looks absolutely sick! This Is the last weekend I have to finish it before I drive to Texas for my wife's bmt graduation. She hasn't seen it or heard about it since I hit my deer Sent from my iPhone using JK-Forum
Old 10-04-2013, 07:17 PM
  #54
Zoglmann's Avatar
Update:
Truss, lca skids, gussets, Trac bar bracket, and rc adj lca's are on. Now to put it back together and install the bullydog
ID:	502702   Click image for larger version
Old 10-06-2013, 07:11 PM
  #55
Zoglmann's Avatar
Bullydog is in and this guy is one happy camper
Old 10-25-2013, 05:42 PM
  #56
Zoglmann's Avatar
Broke an axle shaft today. If I pull it can I run without it? My thoughts are a loose spider gear and oil flowing out the axle tube. Think I'll go with ten factory axles up front but can't afford them just yet. Help!!!!
Old 10-25-2013, 06:46 PM
  #57
Rob 12B1P's Avatar
After pulling the axle I wrapped a rag around a water bottle and duct taped it in the axle tube to keep the oil from running out when I broke mine.
Old 10-26-2013, 06:55 AM
  #58
Zoglmann's Avatar
How long will that buy me you think? Can I run it a couple weeks?
Old 10-26-2013, 01:47 PM
  #59
Former Vendor
Offroad_Elements's Avatar
I wouldn't drive it until the axle is replaced. If you don't have a choice, clean out the axle tube and plug it. Make sure sand, pebbles, or mud doesn't get mixed into the gear oil and mesh with the R&P.
Old 10-26-2013, 06:06 PM
  #60
Zoglmann's Avatar
Ok so what I did was pull the outer shaft on both side s and zip tied the inners into the housing. As long as the unit bearings will run that way I should be good to go. Anything I need to know about running this way or am I ok?
Quick Reply: Zoglmann's Build Thread
