Zoglmann's Build Thread
#51
Started my truss this weekend and the jeep is still a apart. Having issues with my tig. Next weekend it will be getting the truss finished, rc lca's, bullydog gt, fresh Bedliner in spots and paint on some accent peices. Possibly a good buff job as well lol
#52
Good luck with ur tig
#53
Probably gonna go buy a mig this Friday and blow the truss on it. And you gotta get that thing on there! I fit the whole thing and it looks absolutely sick! This Is the last weekend I have to finish it before I drive to Texas for my wife's bmt graduation. She hasn't seen it or heard about it since I hit my deer Sent from my iPhone using JK-Forum
#54
Update:
Truss, lca skids, gussets, Trac bar bracket, and rc adj lca's are on. Now to put it back together and install the bullydog
#56
Broke an axle shaft today. If I pull it can I run without it? My thoughts are a loose spider gear and oil flowing out the axle tube. Think I'll go with ten factory axles up front but can't afford them just yet. Help!!!!
#59
Former Vendor
I wouldn't drive it until the axle is replaced. If you don't have a choice, clean out the axle tube and plug it. Make sure sand, pebbles, or mud doesn't get mixed into the gear oil and mesh with the R&P.
#60
Ok so what I did was pull the outer shaft on both side s and zip tied the inners into the housing. As long as the unit bearings will run that way I should be good to go. Anything I need to know about running this way or am I ok?
