Yet another Trektop thread......Pics
I do like the look; but I agree there seems to be some issue with QC. I remember another top being out there that looks just like the Trek Top; I think it was called Off Road Hero Top, but im not sure... I wonder if the quality is better with that top.
I have the 4door model. I installed mine on a cold day first and it wouldnt even go on properly at all. I did it again on a warm day and it went on smooth and easy and is a perfect fit! There is a bit of tweeking needed to properly line up the header bar to get the least wind noise. A good clue that it is not exactly centered right if you get alot of wind noise at 45+mph. Loosen and adjust the header side to side, make sure it is as far forward in the header channel as possible, retighten the knobs and see if that helps. Just a quarter inch off line and it will be noisy. I also had to adjust the side rods on the window surrounds to get the fit right. Just a little tweeking at a time till it fit right.
Mine is nice and straight, has smooth lines and looks better than a factory top. In fact mine looks as good as the model in the Besttop web site!
Mine is also bone dry.
Guess I got lucky.
My only down side is that the middle of the top really domes up with the AC on outside air and at speeds over 45mph. brainstorming a fix for that. It seems to just be fabric stretch that is inevitable. Maybe sewing in a channel with a crossbow in the middle or two of them.
I'm working on a home made mod to have a roll up strap with a snap alond the top edge of the rear window to roll the window up and strap it in place rather than unzipper and remove it for open air.
Guess I got lucky.
Guess I got lucky.
Guess I got lucky.
IMO there needs to be some rubber gasket or something to go on that little flap because on both sides every once and a while i get rain coming in... you dont have the prob i do as i have the 4 door but on the back doors it is even worse.
I can not believe this. I just called best top to tell them about the problems i am having. Best Top told me to call the place i got it, have them call best top, and that since i had it on my jeep already (and have been driving around for a week with it on), they would send me the new version of the trektop. Get this......best top said that they dont want the top that i have back. Im sure something will go wrong cuz im on here talking about it, but i had to tell somebody.
corey d
corey d
corey d
corey d
