This is why I need a lift!
I finally got to take a trip to Northern Maine for a weekend of snowmobiling. Thought I would take a pic of the JK on the way up and to show why I need a lift. She was a bit freighted with the double axle trailer with two sleds, but I think the two 100lb propane tanks in the back with the rest of the gear almost did it in!
Oh yeah, you know you may be in Northern Maine when the store behind the Jeep sells...........
I won't be towing often and dont mint if it sags a bit. Just don't want it to sag all the way to the wheel wells! Thank goodness my wife doesnt read this. You would have killed my chances for a lift.
looks like that trailer is waaaaaayyyy over center. On My sled trailer the axle is centered pretty much so that the tounge weight is maybee 90-100 lbs at best with my RX-1 and Artic cat zrt 800. I could pick up the trailer by myself when loaded. (Actually sold everything so it isn't "Mine" anymore) however with a close to center axle setup the trailer does "Wag" a bit.
Get a lift but make sure it doesn't get rid of the rake. The rake will help. I'm getting coil spacers with my lift to make sure I still have rake. I haul stuff in the back of my Jeep all the time.
