who is part of the 37 in tire club..(post pics)
#791
Finally! I am in da club!
I rock crawled all over Moab with my YJ with 33's.
When I bought my rig back in early 07, I lifted and installed 35's with less than 500 miles. I thought I would never go bigger. Seems they just look better with 37's.
Here are the new General Grabbers. Just released.
I will let you guys know how they preform in Moab.
Going from Toyo's M/T's to these are great roller's!
#792
#793
JKs just look normal with 37s. Is it because they look like the Jeep Rescue when they are sporting bigger meats?
I need some better pictures and I need to learn how to get them on the site...Something changed.
#794
OK so I was under the impression in order to fit 37's (regardless of lift size) it would require some trimming of the bumper/flares. I am going to be putting a 3.25" suspension lift w/a 1.25" bl on my 4 dr JK soon. I want to run 37s, will I not need to trim? I noticed the green jeep on the first page wasn't stubbied at all
#795
It depends on the overall lift, and more importantly...or at least equally importantly...how you wheel it. If you are gentle with it and either don't off road at all or keep it civilized on the trail, you may be safe without trimming. If you push it, you will most likely scrub your bumpers/fenders/air dam. I have been waiting (semi-patiently) for a 4" Superlift that will allow me to run 37's "with minimal trimming if any at all" according to both their advertisement and their phone support tech. I didn't want to get too involved in a lift (ended up doing way too much to my TJ, eg: SYE, Drive Shafts, Drop Pitman...) so I searched and searched and finally found their kit. Anyhow, long story short...You CAN tuck 37's but the trimming will depend on how you use your new-found flexibility from the lift. If you do rub and don't want to trim, you may be able to get by with some extended bump stops, but you'll have to weigh out the cost of the loss of compression/flexibility.
yea this is my current set up, doesn't seem to rub when turned at full turn, but I haven't been able to actually drive it yet, just turn to check (still waiting on the wheel spacers that are supposed to be here friday)
#796
Besides, there's tons of people running 35's. If you don't run 37's, you can't be in the club, and that wouldn't be much fun.
#797
It probably sounds crazy, particularly here in a modder type forum, but I like the look of the stock flares and bumpers that I would mod the suspension specifically to avoid changing them on my 4 door JK.
Your set-up looks nice. Little bit of rock-rash on the wheel but all in all, simple and sweet. I miss those old MT/R's. I ordered a new set for my TJ to replace the worn ones and when they arrived, I was like "WTF, These aren't Wrangler MT/R's". After a while, they grew on me and I'm ok with the new style, and the whole "Kevlar" thing is a plus, but I'd love to go back to the style you're running.
#798
Here is the first photo I had the time to resize.
It's also the first photo of my new soft top. Thanks to Ceejay5!
#800
