who is part of the 37 in tire club..(post pics)
#3022
You have any pics you can post of your rig...please.
#3023
Do you have a 2012? I haven't heard anyone with 37s say they wanted anything more than 4.88 whether auto or manual. I don't have 37s but am wanting to go that route so not speaking from personal experience just a lot of research and you'd be the first to say that the pentastar needs more gearing then 4.88.
#3024
I'll be honest I'm running 4.10's and auto and haven't had a problem yet. I had 4.88's in my 07 and it wasn't enough gear but the new HP and tranny make a huge difference. Keep in mind I'm in Fl and I have a JKUR. Never changes gears or slows down for overpasses.
#3025
Do you guys get a lot of wobbling/vibrations at highspeeds? I know 37's are hard to balance and mine wobble pretty good above 65. Under 60 they are fine. I did damage one of mine from my pinch seam (before I cut it enough) and maybe that's why I get vibrations. Just wonder other's experience. I have 13.5 x 37 x 18 Mud Grapplers.
Try rotating your tires and see if their is some improvement. A good four tire rotation would be, Back two tires straight forward to Front, Front two tires cross to Rear.
Let us know what if anything happens.......
#3026
#3027
This was just flexing it out to see how much bump stop is needed and what else needs to be trimmed. Driver front still had more droop but I couldnt go up any further seeing as the passenger tire was resting on the inner fender support. Rear has stock control arms all around but I would like to move the axle back a little in the future.
I also threw in a pick on flat ground so you can get an idea of ride height.
#3029
The wobbling / vibration you are talking about seems to be more of an issue with the wider 37's on the market. But even the 37x12.50's get it sometime.
#3030
