Wheel size question.......17", 18"?
Needing rims now that I put a lift on
1. If jeep has 18in and want to switch to 17in do I need a certain offset?
2. What offset do I need if I stay with an 18in size?
Jeeps come stock with 16,17 and 18". My personal preference is 15 or 16" for 35's and under. But you just want to make sure they have 4.5" or less of backspacing.
To answer your question, I'd go 17's. Cost of tires for 18's is ridiculous and they make the tires look smaller unless you're running 40's. My 2 cents, its your jeep tho
While I agree there are more choices for 17" rims and if your changing wheels that's the way to go, I'd like to clear this common misconception up. For some tires (KM2, etc) this is true, it's not an across the board truth. It just looked at 33" Duratracs in 17's and 18's:
285/70/17 - $230 each @ tire rack
275/70/18 - $236 each @ Tire Rack
I think it's hard to call $6 more a tire ridiculous. I agree they do cost more than 15" versions and only slightly more than a 16" version.
But to each their own.
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
![Wink](https://www.jk-forum.com/forums/images/smilies/wink.png)
