What wasn't done to your jk this week
Old 02-15-2016, 03:20 PM
durffjk's Avatar
Originally Posted by nhk19
I debated for same reason. I only get to park in the garage when my wife takes her Expedition to the airport for a business trip. Otherwise I'm outside so...figured what the heck. Currently only have 3" of clearance with door up. Rack is 4" high. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=637803"/>
Damn, you are getting close, I had to stick my head out the window to make sure I would clear after putting the front coils on.
Old 02-15-2016, 03:25 PM
nhk19's Avatar
Yeah.....not bad though. This jk has 3.5" RK lift w/ 37s. Last one had a 5.5" RK w/ 37. It did fit though. Lol. If it snowed I had to shovel or it would rub on the way out.
Old 02-15-2016, 04:23 PM
jeepmojo's Avatar
Default -40 with windchill
Old 02-15-2016, 05:46 PM
justiceboy's Avatar
these have been sitting in my garage for a week, been driving me crazy but go on tom ha
Old 02-17-2016, 02:06 PM
Jonathan_JK's Avatar
Default Custom Rocker switch panel.
I started with 4 layers of fiberglass earlier this week for my curved panel for my front/rear locker switches. After sanding it down it just felt too flimsy so I decided to add another 4 layers of fiberglass weave. So now instead of painting and priming it today Its hanging for at least 24 hours. So no switch panel for my Jeep yet.
*Here is a picture of it, I don't have power windows so its going right over the hole*
Old 02-17-2016, 03:01 PM
Jeepster904's Avatar
4"rough country w/35s
Old 02-19-2016, 03:54 PM
Default Still Working on it.
So I painted it Knowing I was going to need to sand it more. But if you paint it, sanding after can show you the high and low spots.
Anyways I need to square it off and sand it more. But I did do a "Mock" mount of the locker switches. So at least I'm going to know how it fits an looks. This is a picture of the rough Trial run. I'v already sanded down and re-painted. I'll post again once Its dry.
*So I had to take it off sand and re-paint so now its hanging again*
*Update* So its as good as I want to get it. I know I could get it looking better but I'm satisfied with it.
ID:	638232   Click image for larger version
Old 02-21-2016, 03:14 PM
jeepmojo's Avatar
Default are there just wires going to them?
or do they require air inlets to the actual switch ? final looks good !
Old 02-21-2016, 07:52 PM
LVJK's Avatar
Still haven't finished wiring and running air lines on my new ARB twin air under hood mount compressor.
O||||||O
Old 02-24-2016, 01:46 PM
MotoJeeper's Avatar
I tried putting the Drake Rockclaw latches on, but they won't lock in on the passenger side. I can't adjust the upper latch any lower to where it needs to be. It also put a small chip in my freshly painted fender, FML. Needless to say, I took them off and put the old ones on. Waste of $120.
Quick Reply: What wasn't done to your jk this week
