What should i do tire pressure sensor
M getting some 33s and should I get a AEV ProCal Module
Or get new sensors or I have also heard that the old sensors from my stock tires can work also and info????
This is posted in the wrong forum, but to answer your question you can just have the sensors moved from your old wheels to the new ones. The Pro cal will let you change what the sensors should be reading to keep your low tire pressure light from coming on. You can also adjust your speedometer with the Pro cal to make up for the slightly larger tires.
