#9012
I believe the proper response to that question is: For the zombie/(insert your favorite style of apocalypse here) apocalypse, and of course it looks fast and runs purty. Love the blue btw.
#9013
Been a good week for the little JK. After getting the 5.13's installed Monday, it had two days with the doors and windows off. I left the top up, though, as it was hot enough that I didn't want the sun beating down on me. Anyway, since my garage is full of motorcycles, I park on the street. And it's a little inconvenient to put the Jeep together at night, I took nearly everything out of it last night (I left the CB in it). That was its first night on the street "wide open" and everything went fine, but I decided to step up my search for a semi-secure storage solution.
At a local home store, I found a Stanley 24-gallon tool box, model 029025R. I cut two holes in the bottom, above the front-most and rear-most footmans loops that once secured the rear seat. I then ran the long end of a ratchet strap out the rear hole, and passed it under the footman's loop, then back into the box. Both hooks are attached to the front footman's loop. Since that hole is close the front of the box, the straps there would be the most vulnerable to a knife, but since only the steel hooks are (baaaaaarely) seen, the weak link is still the HD plastic. Of course padlocks on the latches round things out.
It's pretty secure, I think. I put my recovery gear and tools in it and I feel pretty confident in the security aspect of it. I'm sure it'll stay put wheeling.
The finished (well, the padlocks aren't on it, and I think the handle slides in a bit more) product, as light was dwindling.
#9015
Got my engine oil, trans oil, and xfers case oil changed for my 30k service. Everything came out looking new, which is good. Still have to check and see what else I need to do for the 30k. Also moved my rear trac bar to the lowest hole on my teraflex HD axle bracket. Still my axle isn't centered right. My rear upper contol arm rubs the frame at full stuff. Time for a adjustable trac bar. Set my toe to help the steering a bit. Was at the stock 1/16", meant to set it at 1/8" but ended up at 3/16" after torquing everything. Have to
see how it works. Feels better but have to keep an eye on tire wear.
#9017
#9018
installed tuffy overhead console, midland cb, cooltech ultramount, and locker mod into the jeep. been driving around top and doorless for about a week. she'll be hitting the beach tomorrow rescuing the dumb 2wd trucks and cars, lol.
#9020
Thanks Roadking, yes it looks and feels great. Took it up to Santa Fe yesterday and was worried about the handling at freeway speeds (75+ mph). I have to say it performed much better than I thought. I think the wider stance due to less backspacing and wider tire helps a bit. Some noticeable loss of power when compared to the 32s but not a huge difference even at 7000 ft.
