#5413
Got the KCs mounted up. 130W Long Range Driving lights. Mounted a switch in the left dash and wired them up with the supplied harness. Pulled 12v off the cigarette lighter for the feed. Only had to bring one wire in thru the firewall. Took about two hours start to finish. They work great. Very bright. Can't wait to try them out on the back roads around here.
#5416
corey d
#5417
Easy to install, but i dont like the way it has velcro to keep it tight (in front above the front seats). It needs some straps to pull the driver and passenger side together to keep it tight. I dont know if i have the older version or what, but it gets loose pretty quick. If best top cant help me, ill probably bring it to an upholstery shop and have some straps sewed on. I like the way it looks though.
corey d
corey d
#5418
that seems like you might have the old top... I dont know that it is different in the 2 door from the 4 door but mine has a strap that takes the top on the driver and passenger side in the middle of the door and pulls it together... only problem I am having with it is that it leaks pretty bad at the seam above the sound bar. If the rain will stop here at some point I would love to try to seal it up but for now its a towel above the sound bar keeping me dry. Which actually isnt that bad because it dampens noise from the top flapping against the soundbar.
corey d
#5420
Here is one I just found online.
