Thanks BOWICON. I wish I could say there is absolutely no rattle. I put dynomat between the box and door. I also used rubber washers on the bolts. I also put dynomat behind the license plate. So, there is VERY little rattle. Only when it's turned up really high, and I rarely listen to it that loud.
Looks like you thought about everything that could cause rattling! I want a sub but like you, I dont need it to be bumpin around town. The stock sound system in these Jeeps just have zero bass. shawnphi1 makes a good point, can you tell us if you are having any problems with the door bending or anything?
Did some much needed maintenance. Didn't realize how bad it was until the new one came in and I saw the difference. The original had been cleaned many times (every time I did an oil change) but I felt it was past it's prime! This is an Airaid filter after about 55k miles. I feel kinda dumb for not doing it earlier. Ironically they come with a sticker that says "This filter never needs replacing. Do not discard." You're supposed to put it on your filter surround hahaha
I haven't had a single problem with this system by the way.
Did some much needed maintenance. Didn't realize how bad it was until the new one came in and I saw the difference. The original had been cleaned many times (every time I did an oil change) but I felt it was past it's prime! This is an Airaid filter after about 55k miles. I feel kinda dumb for not doing it earlier. Ironically they come with a sticker that says "This filter never needs replacing. Do not discard." You're supposed to put it on your filter surround hahaha <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=667494"/> I haven't had a single problem with this system by the way.
