Old 10-29-2016, 08:02 PM
  #47291
--'(OlllllllO)'--'s Avatar
I installed my new off-road lights
Old 10-30-2016, 06:17 AM
  #47292
jku12_jason's Avatar
Originally Posted by LennDogg
Love that hood! Where did you buy it from?
It's the src stingray hood! Got it from 4wd.com. Had a buddy paint and install for me! Came out awesome and definitely adds some aggressiveness to the front!
Old 10-30-2016, 07:12 AM
  #47293
LennDogg's Avatar
Just painted my interior trim pieces! #PoorMansMod
Old 10-30-2016, 09:48 AM
  #47294
GreenJK07's Avatar
Put the doors and top back on for our thanksgiving trip to hot springs and the rest of winter.
Old 11-02-2016, 03:04 AM
  #47295
Sullycon's Avatar
Originally Posted by ConroeJK
Installed Maximus-3 centered winch plate with my Smittybilt XRC and their fog bracket with KC gravity Amber fogs. Nothing left to do now but save for tire carrier, lift and wheels/tires.
What did you use for a mounting plate for the winch?
Old 11-02-2016, 03:58 AM
  #47296
ReconJeep's Avatar
Got rid of the Condition Zero holster mount and replaced it with the one made by Molle Platform Solutions. It's way better thought out. The Condition Zero one comes with a pathetic soft nylon holster which went in the trash directly. The MPS version does not come with a holster, which is the smart way to do it. You can attach a holster various ways. It has two long slots that allows you to clip whatever holster you are carrying on you. It basically simulates the width of a belt. It also has a bunch of holes that match both the Safariland pattern as well as the G-Code RTI pattern. I think it may also work with the Blackhawk pattern too. There are some Molle slots too so you can add pouches on the opposite side.
I installed a Safariland QLS mount because I can swap out the holster depending on pistol and need. All my holsters have the QLS system so it was a no brain to keep using that setup.
It really is such a great and well thought out mount. Way better than the old Condition Zero that was on there and never got it to work properly.
"Ex Umbris Venimus"
Old 11-02-2016, 08:02 AM
  #47297
BigBlueOx's Avatar
Default Backup Camera
A couple months ago I lost my Garmin through theft. I replaced it with a 6" that was backup camera ready. This week I installed the backup cam. I do like to be able to see what's behind me. I hooked it up to the backup lights so when I put it in reverse it comes on automatically. By using a Garmin I can install a second cam on on the new camper that I am buying in January.
ID:	660110 Click image for larger version
ID:	660115 Click image for larger version
While I was concerned about the location of the camera being vulnerable, it seems protected enough being on top of the receiver. We shall see.
Old 11-02-2016, 11:07 AM
  #47298
coastie kyle's Avatar
Originally Posted by pdx-rubicon
Installed a Yakima roof rack using the track system. Nothing like drilling 12 holes in a perfectly good hard top! Also Hooked up (temp) my cb. Have to run antenna cable at some point. Just wanted to try it out today. Pics to follow of Yakima
Attachment 659638
Id like to see more of this rack if you get around to it. I am thinking about buying this soon.
Old 11-02-2016, 05:48 PM
  #47299
supersport126's Avatar
Originally Posted by ReconJeep
Got rid of the Condition Zero holster mount and replaced it with the one made by Molle Platform Solutions. It's way better thought out. The Condition Zero one comes with a pathetic soft nylon holster which went in the trash directly. The MPS version does not come with a holster, which is the smart way to do it. You can attach a holster various ways. It has two long slots that allows you to clip whatever holster you are carrying on you. It basically simulates the width of a belt. It also has a bunch of holes that match both the Safariland pattern as well as the G-Code RTI pattern. I think it may also work with the Blackhawk pattern too. There are some Molle slots too so you can add pouches on the opposite side. I installed a Safariland QLS mount because I can swap out the holster depending on pistol and need. All my holsters have the QLS system so it was a no brain to keep using that setup. It really is such a great and well thought out mount. Way better than the old Condition Zero that was on there and never got it to work properly. "Ex Umbris Venimus"
awesome! will be looking into this!
Old 11-02-2016, 06:05 PM
  #47300
Chuck-The-Ripper's Avatar
Uh oh
