Got rid of the Condition Zero holster mount and replaced it with the one made by Molle Platform Solutions. It's way better thought out. The Condition Zero one comes with a pathetic soft nylon holster which went in the trash directly. The MPS version does not come with a holster, which is the smart way to do it. You can attach a holster various ways. It has two long slots that allows you to clip whatever holster you are carrying on you. It basically simulates the width of a belt. It also has a bunch of holes that match both the Safariland pattern as well as the G-Code RTI pattern. I think it may also work with the Blackhawk pattern too. There are some Molle slots too so you can add pouches on the opposite side.
I installed a Safariland QLS mount because I can swap out the holster depending on pistol and need. All my holsters have the QLS system so it was a no brain to keep using that setup.
It really is such a great and well thought out mount. Way better than the old Condition Zero that was on there and never got it to work properly.
"Ex Umbris Venimus"
Backup Camera
A couple months ago I lost my Garmin through theft. I replaced it with a 6" that was backup camera ready. This week I installed the backup cam. I do like to be able to see what's behind me. I hooked it up to the backup lights so when I put it in reverse it comes on automatically. By using a Garmin I can install a second cam on on the new camper that I am buying in January.
While I was concerned about the location of the camera being vulnerable, it seems protected enough being on top of the receiver. We shall see.
Installed a Yakima roof rack using the track system. Nothing like drilling 12 holes in a perfectly good hard top! Also Hooked up (temp) my cb. Have to run antenna cable at some point. Just wanted to try it out today. Pics to follow of Yakima
Attachment 659638
Attachment 659638
Got rid of the Condition Zero holster mount and replaced it with the one made by Molle Platform Solutions. It's way better thought out. The Condition Zero one comes with a pathetic soft nylon holster which went in the trash directly. The MPS version does not come with a holster, which is the smart way to do it. You can attach a holster various ways. It has two long slots that allows you to clip whatever holster you are carrying on you. It basically simulates the width of a belt. It also has a bunch of holes that match both the Safariland pattern as well as the G-Code RTI pattern. I think it may also work with the Blackhawk pattern too. There are some Molle slots too so you can add pouches on the opposite side. I installed a Safariland QLS mount because I can swap out the holster depending on pistol and need. All my holsters have the QLS system so it was a no brain to keep using that setup. It really is such a great and well thought out mount. Way better than the old Condition Zero that was on there and never got it to work properly. "Ex Umbris Venimus"
