Old 10-05-2016, 10:04 AM
  #47211
Grand Umpah's Avatar
Default Installed back-up camera
Finally got the camera installed and wired, and Normandin in San Jose flashed it for free!
Old 10-05-2016, 10:32 AM
  #47212
vgullotta's Avatar
Normandin is a good dealership. Stay away from Steven's Creek though, they are such a nightmare.
Old 10-05-2016, 12:33 PM
  #47213
realjeep's Avatar
By Rockhard RH-1035 C-Pillar Brace Kit for Jeep Wrangler JK (07-Current) 4/DR Unlimited:
Finished Driver side today
Sorry about the photos not being right side up but JK-forum entered them in that way.
Here are some tips:
If you are going to have the carpet over the bar as I did you will need a spacer washer as they made it slightly short to accommodate those who want to do it over the carpet. Other wise it went in pretty much as described.
Also the instructions say you don't have to remove the top but that is only if you don't have the bar covers. As you can see in the pic I propped up the front so I could get to the zipper. Which is located on top of the cover.
Old 10-05-2016, 03:00 PM
  #47214
ConroeJK's Avatar
Originally Posted by Cajun JK
How are those KC Head Lights??
I like them, there is a cut off line but they are so much better than stock it doesn't bother me. I think the color temp is more white than blue, however, my neighbor commented on my "blue" headlights. KC has a new generation out, two new models, now but I don't have any complaints but I also don't have anything other than stock to compare them to.
Old 10-05-2016, 03:04 PM
  #47215
ConroeJK's Avatar
Originally Posted by Norcal73
will check tonight. Good thinking. Has whatever the tire shop put in them when mounting. Any recommended psi? Thanks for the response
28 was the sweet spot on my KO2s on my last rig.
Old 10-05-2016, 06:27 PM
  #47216
socal73's Avatar
thanks went from 38 (discount tire) o 3 and it made a huge difference. May try 28 tomorrow just worrying Il set off the tpms and have to re air if go too low. Seems like the general consensus is 28psi though.
Old 10-05-2016, 06:28 PM
  #47217
socal73's Avatar
cant type..38 to 30 made a big difference
Old 10-05-2016, 08:02 PM
  #47218
WhiteKnight115's Avatar
Worked on the Jeep today. Installed the Rockhard 4x4 oil/trany skid. Since I don't rock crawl and mostly just to Overland I ended up taking out one of the bolt covers and using just a normal large washer until I can get my Rockhard 4x4 transfer case skid. Also started on the winch for the OEM bumper. Still have some cutting to do on the winch plate. Then finished off with a nice ceegar. Click image for larger version
ID:	658270Click image for larger version
ID:	658272Click image for larger version
ID:	658271Click image for larger version
ID:	658276Click image for larger version
ID:	658275Click image for larger version
ID:	658273Click image for larger version
ID:	658277Click image for larger version
ID:	658279Click image for larger version
ID:	658278Click image for larger version
ID:	658281Click image for larger version
ID:	658280Click image for larger version
Old 10-06-2016, 02:45 AM
  #47219
Stephane87's Avatar
Originally Posted by realjeep
By Rockhard RH-1035 C-Pillar Brace Kit for Jeep Wrangler JK (07-Current) 4/DR Unlimited: Finished Driver side today Sorry about the photos not being right side up but JK-forum entered them in that way. Here are some tips: If you are going to have the carpet over the bar as I did you will need a spacer washer as they made it slightly short to accommodate those who want to do it over the carpet. Other wise it went in pretty much as described. Also the instructions say you don't have to remove the top but that is only if you don't have the bar covers. As you can see in the pic I propped up the front so I could get to the zipper. Which is located on top of the cover.
Please, can you try to send those pictures again? They don't show?!?!
Thanks
Old 10-06-2016, 01:54 PM
  #47220
outlaw26's Avatar
Built a new rear bumper
ID:	658318   Click image for larger version
