By Rockhard RH-1035 C-Pillar Brace Kit for Jeep Wrangler JK (07-Current) 4/DR Unlimited:
Finished Driver side today
Sorry about the photos not being right side up but JK-forum entered them in that way.
Here are some tips:
If you are going to have the carpet over the bar as I did you will need a spacer washer as they made it slightly short to accommodate those who want to do it over the carpet. Other wise it went in pretty much as described.
Also the instructions say you don't have to remove the top but that is only if you don't have the bar covers. As you can see in the pic I propped up the front so I could get to the zipper. Which is located on top of the cover.
Here are some tips:
I like them, there is a cut off line but they are so much better than stock it doesn't bother me. I think the color temp is more white than blue, however, my neighbor commented on my "blue" headlights. KC has a new generation out, two new models, now but I don't have any complaints but I also don't have anything other than stock to compare them to.
Worked on the Jeep today. Installed the Rockhard 4x4 oil/trany skid. Since I don't rock crawl and mostly just to Overland I ended up taking out one of the bolt covers and using just a normal large washer until I can get my Rockhard 4x4 transfer case skid. Also started on the winch for the OEM bumper. Still have some cutting to do on the winch plate. Then finished off with a nice ceegar.
By Rockhard RH-1035 C-Pillar Brace Kit for Jeep Wrangler JK (07-Current) 4/DR Unlimited: Finished Driver side today Sorry about the photos not being right side up but JK-forum entered them in that way. Here are some tips: If you are going to have the carpet over the bar as I did you will need a spacer washer as they made it slightly short to accommodate those who want to do it over the carpet. Other wise it went in pretty much as described. Also the instructions say you don't have to remove the top but that is only if you don't have the bar covers. As you can see in the pic I propped up the front so I could get to the zipper. Which is located on top of the cover.
Thanks
