Old 06-28-2016, 06:20 PM
  #46811
Machoo's Avatar
Teraflex tailgate table!
Haven't gotten to use it on the trail yet but I will soon. For now it holds beer pretty well!!
Old 06-29-2016, 04:29 AM
  #46812
pbujku13's Avatar
Default Stop
Badly needed brake pads.. and then the rotors looked bad....
I ended up replacing all the braking system.
Mopar Big Brake kit: 13-inch rotors, dual piston calipers, brake lines, heavy-duty pads, booster, and master cylinder.
And in rear the Dynatrac ProGrip 14 1/4-inch rear rotors, caliper brackets and pads.
It stops very well now.
Old 06-29-2016, 06:39 AM
  #46813
0escape5's Avatar
Originally Posted by greynolds08
My Jeep went back to the FREAKING Shop again!!!!! This time it's the transmission not shifiting and check engine light is on
Is your traction control light on too? Did you happen to hit a large bump or pothole recently? I had an engine light and the traction control light came on shortly after and it caused me to lose shifting. It could be a bad camshaft sensor. Both of my lights turned off recently so I'm praying they stay off.
Old 06-29-2016, 09:01 AM
  #46814
Stephane87's Avatar
Originally Posted by pbujku13
Badly needed brake pads.. and then the rotors looked bad.... I ended up replacing all the braking system. Mopar Big Brake kit: 13-inch rotors, dual piston calipers, brake lines, heavy-duty pads, booster, and master cylinder. And in rear the Dynatrac ProGrip 14 1/4-inch rear rotors, caliper brackets and pads. It stops very well now.
Pictures?
Old 06-29-2016, 10:10 AM
  #46815
karls10jk's Avatar
Replaced the drag link after kicking the wheel off 90* in a national park. Build, play, break, repeat.
Old 06-29-2016, 10:22 AM
  #46816
pbujku13's Avatar
Originally Posted by Stephane87
Pictures?
Sorry, no good install or comparison shots, or ofthe master cylinder or brake booster.
All I got is the after photos.
ID:	651002Click image for larger version
Old 06-29-2016, 10:53 AM
  #46817
afpilot82's Avatar
Air and TF tailgate table.
Old 06-29-2016, 12:29 PM
  #46818
missouri_sooner's Avatar
So I found my daughter a jeep this weekend for her Bday. It's an 08 with only 29,000 miles it was lifted already with stock wheels and tires! So I did what any dad would do and traded out until I can find her some wheels and tires. Now my 4door with a 4.5in BDS lift is sitting on stockers. But this is my first time driving and 2 door and I have to say I may need to make a switch. I love my 4 door but driving the 2 door was so much more fun!
ID:	651016Click image for larger version
Old 06-29-2016, 12:52 PM
  #46819
turkeyfunk7's Avatar
KO2's, fire extinguisher, rear brake pads, and lifetime max care package
Old 06-29-2016, 02:01 PM
  #46820
mdiacity's Avatar
Got my grill back from paint and did the DIY gutter screen inserts
