I kept and trimmed the inner plastic fender support and on the front section there is a place for a push tab. So I drilled it out to fit the light and wired it into the factory plug. The light body is threaded with a nut so it fits perfect and tight.
I thought the install was fairly easy. The quality seems real nice with the powder coat and the aluminum. I went ahead and ordered a Astro riv nut tool from Amazon with the fenders. I think for front and rear with the tool and led side lights it was around $700. The tool makes setting the nuts very easy and tight. The fenders all matched factory holes with only one extra hole to drill in the rear. I had to modify a couple washers to fit but nothing major. Probably a 3-5 hrs job if you take your time.
