A new Billet Light Bar Kit and Kat Walk from Kargo Master Safari
Adam's Jeep Got a Kat-Walk and a Billet Light Bar Kit from Kargo Master Safari! Looks pretty awesome... Lights up the night and you can stand on the Kat-Walk....
I saw the Switch-Pro advertised somewhere after I had my sPOD on order. The sPOD will suffice for all my needs. Easy install and very neat appearance wise. I like mine just fine. Regardless of brand they're all better than the old way of running tons of wires between the device, the battery, switches in the cab and screwing relays fast all over the engine compartment. Congrats on your purchase!
Looking for the quietest but most aggressive looking tires. Size 35 for 20in rims...
I have 2012 jk 4DW. Right now I'm riding stock but plan on buying new tires soon. I want the quietest but most aggressive looking tire out? I want 35's for a 20in rim. It's a daily driver and I do not mud (Sin I know). Anyways I need help with this decision and suggestions would be appreciated! Thanks
It might get the look your looking for but you will pay for the 20"rim to tire ratio from your piggy bank. Then consider, the wheels will be heavier because of the 20" rim then the extra amount of rubber. I'm not trying to insult you but ask if the pro's out weigh the cons good sir. Either way, good luck on your build.
Thanks for the advice. I appreciate it.
KM Safari Pro Series Kat-Walk
The Kat-Walk PN# 60255 ($258) has to be used with the Congo PRO Front Hoop Light bar PN# 55015 ($290)
The Light Mount Kit (Billet Anodized Aluminum) is PN# 60300 ($97)
Trick, Modular and Heavy Duty! ( will hold up two big guys...)
All bolts on easily, no drilling required. Powder coat finished!
Quadratec has them, 4WD Hardware and we can sell them. msg me with your direct e-mail if you want to make a purchase
-Travis
Longer Descriptions if your interested:
55015 Congo Pro Front Hoop JK: Congo Pro Front Hoop JK, windshield-frame mounted, expedition load and light bar with weld-on integrated grab handles. Rigid 2″ tubular steel hoop, mounts over and around Jeep JK windshield area. Industrial grade bolts secure to the JK’s A-Frame posts. Congo Pro Front Hoop JK provides forward bracing and attachment for Congo Pro Cage system (PN#’s 55000, 55010) and the JK Low-Pro Roof Rack system (PN# 55040). Congo Pro Front Hoop JK can be used as a standalone component and will accept KMS Large Light kits and Standoff Brackets. NO-DRILL INSTALLATION.
· Heavy-duty 2″ diameter x .120″ steel tube, strongest available.
· Integrated grab handles.
· Wrangler JK only.
· Nationwide lifetime frame warranty
· Industrial grade fasteners for added strength and corrosion resistance.
· Superior off-road protection for windshield assembly.
· Accessory brackets are available to mount our additional mounts
60255 Kat-Walk JK: Across the hood, modular foot platform, bolt-on designed for the Congo Pro JK Front Hoop. Sturdy tubular steel construction with diamond plate steel decking for foot traction surface area. Integrated design does not obstruct driver view. Use with Hinge Step and Rocker Walk JK is recommended for complete roof-top access system. Marine grade powder coat finish. NO-DRILL INSTALLATION.
· Easy one-step installation.
· Sold and installed as an additional attachment to Congo Pro JK Front Hoop.
· Rigid steel construction rated for 300lbs.
· Design does not trap mud or grime, easy to clean.
-Travis
· Wrangler JK only.
