Put on new rear bumper w/tire carrier last night.
Attachment 613887
Anyone know who makes the best third light extension that mounts to rear gate panel instead of tire carrier. Don't want a bunch of loose wire!!
Attachment 613887
Replaced the pcv valve, spark plugs and wires. Pcv and plugs weren't much trouble but the wires were a PITA. One bit of advice for anyone tackling this job..unplug all the wires from the plugs and coil pack and pull the wire holder with all wires still attached. You'll most definitely break the holder if not. Once out, its much easier to figure out where to pry to release the wires. You'll also be able to match up new wires to old and replace as an "assembly". I used a couple wraps of electrical tape on the three boots that went around the back of the engine to the coil and made a hook with a coat hanger to pull them through.
Finally got around and installed Rubi shocks and JKU springs 17/58 on my JK. I had 14/56 springs originally. It took me 7 hours with a lunch break. I like the result. I achieved a level stance and stiffer ride which I like. The original suspension felt like jelly. Highly recommend for anyone who's looking for a minimum lift and level stance.
Looks like you are missing some wheel studs?
