Old 05-29-2015, 03:57 PM
  #43831
jkeleig's Avatar
Shorty!!!
Old 05-29-2015, 04:03 PM
  #43832
jkeleig's Avatar
Welp,... It's undeniably, "Hers"... Now!!!
Old 05-29-2015, 04:04 PM
  #43833
jkeleig's Avatar
Old 05-29-2015, 04:18 PM
  #43834
ill1cit's Avatar
Originally Posted by jeepmojo
wondering if i can add these to a stock height jk 2 door ? with out being lifted just to replace my stock lca due to pitted or if id benifit at all or maybe it would just cause problems and more work than its worth , do you gain anything over stock lca if so how ? thanks
I'm not sure. I know they're a lot beefier than the stock control arms. They weigh prob 3x as much. The joints are def way better then the factory bushings. If you are looking to pick up a set 4WD is running a 10% off special on RK products. They are also doing free shipping. I ended up getting them for $251.99 shipped.
Old 05-30-2015, 02:44 AM
  #43835
14Sport's Avatar
Im not to sure if it would handle any better such as more flex or would i not see any type improvement ? maybe just open up a can of worms such as adjustment issues or alignment then needed on a machine ? Ive thought about this in past but just left them stock so far
thanks for a reply on that
I doubt you would see any improvement in handling. But it would be one less thing to need if you ever plan to lift the Jeep. Then you could use them to correct caster.
Old 05-30-2015, 04:51 AM
  #43836
VaderJK12's Avatar
Rampage Stubby installed
Old 05-30-2015, 06:42 AM
  #43837
twinz33's Avatar
Took a picture
  #43838
Bubbacon's Avatar
Used my home made door cart for the first time that I made last year. Just hung them previusly... But liking the notion of the wheeled cart.
Old 05-30-2015, 01:00 PM
  #43839
JKJody's Avatar
Prorock44 unlimited, rcv shafts, 4:88's and arb installed along with PSC hydro assist. Also arb compressor and an Spod all mounted and wired up.
Old 05-30-2015, 04:04 PM
  #43840
Grand Umpah's Avatar
Default Finally, a real set of horns
Installed Blaster horns behind the grill of my '12 JKUR
Can't believe I waited that long...
