Old 05-04-2015, 02:41 PM
  #43521
7kings's Avatar
Originally Posted by 14Sport
I do. I'll give him a call and I also got a name in Tampa to try.
The new shop I emailed sent me a quote today of 2150 with 2 master install kits, or 1840 without the master install kits since I have a 14. And he said he would add the lockers for just the cost of the parts.
Definitely give Wurx a call - I think the quotes I've seen from them with master install kits are a few hundred less than that.
Old 05-04-2015, 03:00 PM
  #43522
14Sport's Avatar
That quote included the taxes too. He charges 450 per axle for install.
Old 05-04-2015, 05:53 PM
  #43523
D_engel's Avatar
That still seems high. Going rate out here is $1100 out the door for gears, master overhaul, fluids, labor and tax.
Old 05-04-2015, 06:16 PM
  #43524
conquerfool's Avatar
finally put on the Mopar bumper that I picked up cheap on Craigslist, took the tubes off and I'm thinking I'm going to bedline all of it, the back bumper should be going on this weekend hopefully
I also finally got the stubby Antenna X on, Vector UFOs, and new hood latches (Goodbye hood flutter). Also gave it a good bath and wax over the weekend.
Was at the Home Depot today and picked up everything I need to make myself a cart for my doors, going to finally get those off and be fully naked just in time for spring in MA.
ID:	609383Click image for larger version
ID:	609384Click image for larger version
ID:	609385Click image for larger version
Old 05-04-2015, 06:21 PM
  #43525
axendo79's Avatar
Worked on putting my bumper and winch on tonight. Gotta finish up with the wiring hopefully tomorrow and then start saving for flat fenders and 37s.
Old 05-04-2015, 07:10 PM
  #43526
MikeTHIS's Avatar
Oh just some small stuff...
ID:	609390   Click image for larger version
ID:	609391   Click image for larger version
Old 05-04-2015, 07:37 PM
  #43527
MotoJeeper's Avatar
I've thought about doing that. How hard was that to do?
Old 05-04-2015, 07:53 PM
  #43528
Graebicon's Avatar
My custom CAI.................Volant CAI.......little power increase and throttle response.......this plus Gibson performance. Exhaust......getting 16mpg in town......17mpg highway and 19 mpg Interstate....plus does well in car-show competitions!
Old 05-04-2015, 07:57 PM
  #43529
Graebicon's Avatar
Installed Hilift jack (patriot edition)in rear section of GRAEBICON!
Old 05-05-2015, 01:28 AM
  #43530
MikeTHIS's Avatar
Depends on your patience level and if you've soldered before. Took me about 20 min after verifying the voltage at the LED was 3.4 vdc. It's 12 vdc into the board at the wires but there's some resistors on the board already.
White and a few other color LED's run at 3.4, make sure you research before buying.
I'll be doing the rear view mirror map lights next. I may also test the two small lights that are on low power when headlights are on in the footwell as well.
