1. Rampage front bumper
2. Smittybuilt rear bumper
3. Pavement Ends Sprint top
4. 2.5" rough country lift
5. Plasti-dip grill
Tires and rims in the next few weeks
5. Plasti-dip grill
I hope you got momentary. It would suck to hit that switch by accident. I did a similar in-cab control, only I added a winch power ON/OFF switch tied into the IN/OUT so there's little chance of accidentally engaging the winch when I don't want to.
Attachment 599284
Attachment 599284
Added a TeraFlex leveling kit yesterday. While certainly within my skill level to manage, the provided instructions were quite limited and did not take everything into account. Especially in the rear, when lowering the axle, one should loosen the e-brake cables and wheel speed wiring to obtain the clearance needed to remove the springs. My springs also required some compression and strong negotiation to re-install them with the spacers in place. The front was more straight forward. Overall, the process took 3 hours from before pics to after pics and clean up.
Before leveling kit
After leveling kit
Before leveling kit
After leveling kit
I've been on the fence for which way to go on the steering. Was leaning towards the fox ATI unit but maybe i will check out the red neck hydro unit. What bump stops did you go with? Did you do any limiting straps?
Added a TeraFlex leveling kit yesterday. While certainly within my skill level to manage, the provided instructions were quite limited and did not take everything into account. Especially in the rear, when lowering the axle, one should loosen the e-brake cables and wheel speed wiring to obtain the clearance needed to remove the springs. My springs also required some compression and strong negotiation to re-install them with the spacers in place. The front was more straight forward. Overall, the process took 3 hours from before pics to after pics and clean up. Before leveling kit <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=599362"/> After leveling kit <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=599363"/>
Ordered my first JK
Order my first JK Unlimited Hard Rock. It is a Sunset Orange, 23J, 430, Automatic A/C with a hard top. Also with the AEV JK351 package.
Very excited about it. Can't wait to get it.
