Old 06-07-2014, 01:53 PM
  #39901
AF_SGT's Avatar
Installed my Poison Spyder body armor. When the paint drysthe Rocker knockers will be going onas well....
Old 06-07-2014, 03:20 PM
  #39902
BigJuice10's Avatar
Truck-lite headlights! What a difference!
ID:	558147   Click image for larger version
ID:	558148   Click image for larger version
ID:	558149   Click image for larger version
Old 06-07-2014, 03:23 PM
  #39903
Jp3792's Avatar
Changed diff fluid..
Lol can we say im a few months behind? Lol
Old 06-07-2014, 03:26 PM
  #39904
Jp3792's Avatar
Originally Posted by Rbzak
Added heavy duty rear d ring mount to factory bumper.
As much as i hate to say it.. you dont want gap in between that. That plate will twist that frame only bolted onto one side.. id suggest going through both sides of the frame. Just my 2 cents. Nice job though!
Old 06-07-2014, 03:36 PM
  #39905
Rbzak's Avatar
I have mounted them just like the factory tow hooks. Two bolts on top and two on bottom part of the frame. With 1/4" angle iron.
Old 06-07-2014, 04:51 PM
  #39906
46chevytruck's Avatar
Spent the day sanding down the bubbled paint on my door hinges and taillight guards and then sprayed them with Bedliner. Click image for larger version
ID:	558166 Was amazed at the amount of corrosion behind the hinges!!!!! Click image for larger version
ID:	558169 Click image for larger version
ID:	558168 Click image for larger version
ID:	558171 Click image for larger version
ID:	558179 I then ran a new ground wire from my battery to the alternator to see if it will solve the intermittent starting "click"/fail. Click image for larger version
ID:	558183 Click image for larger version
Next project is installing the Poison Spyder Rocker Knockers and hood louvers.
Old 06-07-2014, 04:57 PM
  #39907
JustJKing's Avatar
Mounted an external speaker for the cb so that I can hear people squawk at me on the highway with the arm rest down.
Old 06-07-2014, 05:53 PM
  #39908
jkrubcon's Avatar
Originally Posted by 46chevytruck
Spent the day sanding down the bubbled paint on my door hinges and taillight guards and then sprayed them with Bedliner. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558166"/> Was amazed at the amount of corrosion behind the hinges!!!!! <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558169"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558168"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558171"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558179"/> I then ran a new ground wire from my battery to the alternator to see if it will solve the intermittent starting "click"/fail. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558183"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558181"/> Next project is installing the Poison Spyder Rocker Knockers and hood louvers.
Where did you get the Made in USA decal? Pixi?
Old 06-07-2014, 06:21 PM
  #39909
No clue who the seller was. eBay.
Old 06-07-2014, 06:39 PM
  #39910
Bubbacon's Avatar
Installed my new carbon fiber air scoop. Cutting the hood was fun :-) went through 3 dremel steel cut blades... Went with stainless rivets - i like the contrast on the carbon fiber. Wife came out and saw me mid job and said "you cut a hole in your jeep hood?!?, are u nuts". I just smiled. Next up... The shark gill heat vents - but leaving those for next week.
