I have mounted them just like the factory tow hooks. Two bolts on top and two on bottom part of the frame. With 1/4" angle iron.
Spent the day sanding down the bubbled paint on my door hinges and taillight guards and then sprayed them with Bedliner. Was amazed at the amount of corrosion behind the hinges!!!!! I then ran a new ground wire from my battery to the alternator to see if it will solve the intermittent starting "click"/fail.
Next project is installing the Poison Spyder Rocker Knockers and hood louvers.
Spent the day sanding down the bubbled paint on my door hinges and taillight guards and then sprayed them with Bedliner. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558166"/> Was amazed at the amount of corrosion behind the hinges!!!!! <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558169"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558168"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558171"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558179"/> I then ran a new ground wire from my battery to the alternator to see if it will solve the intermittent starting "click"/fail. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558183"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=558181"/> Next project is installing the Poison Spyder Rocker Knockers and hood louvers.
Installed my new carbon fiber air scoop. Cutting the hood was fun :-) went through 3 dremel steel cut blades... Went with stainless rivets - i like the contrast on the carbon fiber. Wife came out and saw me mid job and said "you cut a hole in your jeep hood?!?, are u nuts". I just smiled. Next up... The shark gill heat vents - but leaving those for next week.
