![](http://img.tapatalk.com/d/14/05/12/u4u4ybu3.jpg)
![](http://img.tapatalk.com/d/14/05/12/da6e2y5a.jpg)
Glad you like it. It works flawlessly and is completely custom to fit your needs. There's a write up I did if you look up DIY fuse box.
Thank you! This is the third one I've made, this one is 6.5"x5"x4.5" so its small enough to be mounted anywhere under the hood. The other one I made mounted right above the battery. The one I use has 7 relays and 5 direct battery lines, all fused and with an inline circuit breaker, and its waterproof.![](http://img.tapatalk.com/d/14/05/12/u4u4ybu3.jpg)
Anyway, to each his own.
![Wink](https://www.jk-forum.com/forums/images/smilies/wink.png)
The pre-cleaner makes tons of difference and a lot of times you can see that trail dust hangs around that 2 to 5 foot level thinning out at the upper end so raising the intake can have a large effect on how much dirt your air filter has to hold on an extended trip out
Glad you like it. It works flawlessly and is completely custom to fit your needs. There's a write up I did if you look up DIY fuse box. Thank you! This is the third one I've made, this one is 6.5"x5"x4.5" so its small enough to be mounted anywhere under the hood. The other one I made mounted right above the battery. The one I use has 7 relays and 5 direct battery lines, all fused and with an inline circuit breaker, and its waterproof.
I put mine on the other day. If it's warm out and u do it in the precise order they state in the instructions it is only slightly miserable...
