Bumper is the 2.5" spyder led and on the tail lights rigid sr-m back up light kit.
http://www.rigidindustries.com/led-lighting?f[0]=field_product_family%3A9&f[1]=field_optics%3A102&f[2]=field_product_family%3A1528
Installed the JeepSWAG Stealth Hi-Lift Jack Mount. It's mounted at the top of the rear roll cage. Also put in the quick fist mounts and 4 fists. I haven't found any writeups on this one, so I'll do one of those soon.
Former Member
1 Post
So made some rear lower control arm mount pockets to cut 1.5" off bottom and move shock up while adding a skid.
I can make em with bolt holes but did side cutouts on mine to to go around the bolt and reduce e weight since the rear control arm bracket is still what's welded to axle...
The small cut out parts are for front shock relocation brackets they take shock out 1.5" up 1.3" and rotate the shock end 90*.
So tomorrow is cutting day and all the mounts will be redone and modified...then adjust bumps and go put it on the wall for flex and check. Getting it dialed for the 16th annual superstition run this month...
Have a spare rear axle sitting here so started making stuff on it....
