Don't be skerred. Lol. Just follow the many writeups and it's honestly very easy I found. Hardest part is figuring out what design you want and then taping it off. Cutting is easy. Jigsaw is by far the easiest to use to cut. Don't know why it's not used more often.
Former Member
1 Post
Lifted the jeep another 1.5" finally got it where I want...
Did locker over ride so I can control front or rear seperatly and 4hi if needed as well as rear in 2hi.
Made my own spring retainers front and rear to hold the springs in so I can now relocate shock mounts...
Bent the front clips over a bolt same size as spring and the rear plates are body mount washers and welded the threaded bolt end to the perch.
