Old 12-11-2013, 06:26 PM
  #36701
040jk's Avatar
Originally Posted by One bad black JK
Did you get the Radius lights? I have been looking at a set but can't decide. Did you get the fog or spot light and how bright are they?
Sorry I haven't been on in a few days. I got the spot and they don't throw the beam as far as I would like. In fact the hella 500ff spot lights I had on my other jeep worked better but they are brighter than the sun. Lol.
Old 12-11-2013, 06:35 PM
  #36702
040jk's Avatar
Originally Posted by AU_Guy
Any quantifiable results w/ the tuner?
It feels a little stronger. I mainly got it to recal the speedo for tires and my jeep came with the 3.21 gears and I want to change them to something better so I would need the programmer for that. The best feature I have found is the adj to the drive by wire pedal. Set to superchips setting the throttle response is much, much, much better. Driving it to work this week about 45 miles almost all interstate and the trip computer is showing .8 to 1 mpg better than it was before the programmer
Old 12-11-2013, 06:40 PM
  #36703
040jk's Avatar
Swapped out my fog lights for amber and my piaa 520s to ion yellow.... Pics don't do it justice..... Sent from my obama monitoring device
I really like ur amber fogs. I have the led windshield lights 6000k hid headlights and wanted to change my fogs out too. What did u use and where did u get the bulbs from
Old 12-11-2013, 08:11 PM
  #36704
Jersey_Devil's Avatar
Thank you! Here's the links. There led/smd, I got them on eBay for 30 bucks, I also have a 6000k to match my trucklites
Amber - http://www.ebay.com/itm/271006845159...84.m1439.l2649
Cool blue - http://www.ebay.com/itm/High-Power-W...577071?vxp=mtr
There are 3 small tabs (2 on one side and 1 on the other) U need to take a pair of wire cutters and trim them flush with bulb (don't have to be perfect, just a Lil trim so they fit in the factory slots. The tabs on the led bulbs are slightly fatter
Old 12-11-2013, 09:21 PM
  #36705
bombout800's Avatar
Originally Posted by 1978cj7jk2012
yeah man too bad you aren't closer I could help you out!
I appreciate that. If I ever get In a bind I'll give you a shout!
Old 12-11-2013, 09:34 PM
  #36706
bombout800's Avatar
I appreciate that! If I ever get in a bind and need some work done I'll let you know
Old 12-12-2013, 06:10 AM
  #36707
reddenedbeard's Avatar
Uniden 520xl CB installed in the center console .. Firestick behind the spare.
ID:	516363Click image for larger version
Old 12-12-2013, 02:04 PM
  #36708
1978cj7jk2012's Avatar
Originally Posted by D_engel
You will be surprised how easily those will get hung up. My factory frame side brackets folded in on themselves after bashing them a few times. They are definitely worth the money and the small risk though, especially if they are strong enough to handle the abuse. Do you know how thick the material is?
yeah that are 3/16 inch steel
Old 12-12-2013, 03:34 PM
  #36709
stangmike1's Avatar
My jeep is a 2008 and My clutch slave cylinder gave up at 52000 miles so I had to have it towed to the dealer.
Lucky me I have extended warranty and the deductible is $100 lol.
Old 12-12-2013, 05:18 PM
  #36710
lobster86's Avatar
literally less than 2 inches. The fact that the brackets themselves don't go lower than the lowest part of the control arm makes me think I would be pretty hard to get hung up on them. For The difference that it makes with the ride it's defiantly worth the risk,
It looks like if you're doing any kind of rock crawling those could be a big liability. Do they help out mainly with on road driving?
