Picked up my KOR bumpers this past weekend and got them installed throughout the week. I also put a set of Rigid Duallys in the front and rear and Rotopax system with the backplate from KOR. Still have to install the tire carrier and Warn Zeon 8.
Lift, wheels and tires in the future...![Click image for larger version
ID: 506021](https://www.jk-forum.com/forums/attachment.php?attachmentid=506021&thumb=1&d=1513720268)
Onboard air and water. Water held in stock bumper with RV water pump mounted under. Q Industries MV50 Air Compressor with 2.5 Gallon tank mounted on rollbar in cargo area. Removed spring from rear headrests so they stay down for better rear visibility. Fire ext., axe, shovel, and air comp. all mounted in cargo area. Axe and shovel mounted on "L" brackets using hardtop bolts. Panel on side for air and water made of sheet steel from Home Depot. I painted it w/ rust proofing paint and then Plasti Dip'd it, rubber mat under to help seal against body. Vinyl stickers came from Moyer Custom Vinyl Decals. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506006"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506007"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506008"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506009"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506010"/>
Former Member
1 Post
Got under the jeep and noticed the lower control arms in rear were bent from the last run...
So I've got 2 sets of stockers and not ready to 3/4 link the jeep till I do the d60 14 bolt so beefing up a set was the perfect plan for the problem....I might make a set of arms with metalcloak joints to pass the time till I link but these are now stout and can be hammered Into stuff.
Took a piece of 120 wall 1.5 Dom and cut it length wise. Took another set of rear lowers cleaned em up and overlayed it welded it up and good to go play in the rocks....
![](http://lp1.pinkbike.org/p4pb10228554/p4pb10228554.jpg)
![](http://lp1.pinkbike.org/p4pb10228555/p4pb10228555.jpg)
![](http://lp1.pinkbike.org/p4pb10228556/p4pb10228556.jpg)
So I've got 2 sets of stockers and not ready to link the jeep till I do the d60 14 bolt so beefing up a set was the perfect plan for the problem....I might make a set of arms with metalcloak joints to pass the time till I link but these are now stout and can be hammered Into stuff.
Took a piece of 120 wall 1.5 Dom and cut it length wise. Took another set of rear lowers cleaned em up and overplayed it welded it up and good to go plavy in the rocks....
Sent from my obama monitoring device
Attachment 506006Attachment 506007Attachment 506008Attachment 506009Attachment 506010
Sent from my SM-N900T
