Custom Jerry Can Mount
Replaced factory front trackbar with JKS adjustable, replaced steering stabilizer with bilstein stabilizer and replaced factory bolts in both trackbars and lower control arms to 9/16" grade 9 shouldered bolts... Can't believe the damage the factory bolts can do! Rear tire carrier is next! Attachment 505816
Just a few of my mods
Onboard air and water. Water held in stock bumper with RV water pump mounted under. Q Industries MV50 Air Compressor with 2.5 Gallon tank mounted on rollbar in cargo area. Removed spring from rear headrests so they stay down for better rear visibility. Fire ext., axe, shovel, and air comp. all mounted in cargo area. Axe and shovel mounted on "L" brackets using hardtop bolts. Panel on side for air and water made of sheet steel from Home Depot. I painted it w/ rust proofing paint and then Plasti Dip'd it, rubber mat under to help seal against body. Vinyl stickers came from Moyer Custom Vinyl Decals.
Onboard air and water. Water held in stock bumper with RV water pump mounted under. Q Industries MV50 Air Compressor with 2.5 Gallon tank mounted on rollbar in cargo area. Removed spring from rear headrests so they stay down for better rear visibility. Fire ext., axe, shovel, and air comp. all mounted in cargo area. Axe and shovel mounted on "L" brackets using hardtop bolts. Panel on side for air and water made of sheet steel from Home Depot. I painted it w/ rust proofing paint and then Plasti Dip'd it, rubber mat under to help seal against body. Vinyl stickers came from Moyer Custom Vinyl Decals. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506006"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506007"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506008"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506009"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=506010"/>
