Old 08-02-2013, 10:06 AM
  #34121
Kewman33's Avatar
Default JW Speaker and Fog Install
Headlights First; TLG-Auto.com with Anti Flicker harness
Plug and play; drivers side (left) I had to dremel some modification in the 2012 to get it to seat right.
Fogs, brackets TLG-Auto.com with fog plug and play adapters; patience def needed here!
Had to cut into bumper to make fog light hole larger, Then, carefully placed brackets over factory holes and threaded the bolts into the factory hole with a screw driver (ONLY) don't over tighten! Trick is to pre start every screw before lining up brackets. I then used a large zip tie over each fog light and screwed into bumper for added security and tightness. I was a little worried at first because the fogs do not actually seat into the fog light factory holes, but don't worry once secured, ant the bumper is back on it looks awesome.
I have posted some pics and there are some youtube videos on the install, just take your time. Will tell you that the jeep will look funny without the matching fogs, the factory fogs look very yellow compared the jw speakers of course.
Good Luck!
ID:	484408   Click image for larger version
ID:	484409   Click image for larger version
ID:	484410   Click image for larger version
Old 08-02-2013, 10:20 AM
  #34122
Kewman33's Avatar
Default Gibson Metal Mulisha Cat Back 2012 - Awesome
Must say I was skeptical about this as I didn't want it to be obnoxiously LOUD! Well after the less than 45 minute install, I am very happy. Install was simple: disconnect neg battery terminal so computer with adjust and reset with the new exhaust, disconnect on factory bolt, disconnect welded hangers from the factory rubber grommets and remove stock. Connect the new Gibson, attach the factory rubber grommets to the new Gibson hangers, attach the Gibson supplied UBOLT pipe connector and tighten firmly. Attach the awesome metal mulisha exhaust tips ( I pushed mine back as far as they would go and they stick out the back just right! Reattach neg battery terminal and you are done. Start engine and check for exhaust leaks at ubolt and recheck all bolts after 50 miles. Good Luck! Oh, most importantly, partsgeek.com, 409 delivered. Search web for coupons, SAV15 cut it $15 bucks off for me, the already very low price.
ID:	484412   Click image for larger version
Old 08-02-2013, 10:36 AM
  #34123
nickell586's Avatar
Looks good. I'd be worried about ripping it off though
sent from rooted oc s3
Old 08-02-2013, 10:41 AM
  #34124
Nflores's Avatar
Default Named the Jeep
Finally named the Jeep properly
Avinash is "indestructible" in Sanskrit
Old 08-02-2013, 10:47 AM
  #34125
USMC Wrangler's Avatar
Good Luck!
Nice! What are the part numbers you used for the lights?
Old 08-02-2013, 11:57 AM
  #34126
stangmike1's Avatar
Good Luck!
Dude You know that the evolutions are plug-and-play right???
Took me 10 minutes to install mine.
Old 08-02-2013, 12:12 PM
  #34127
lonewolf23's Avatar
Default Personalized
I gave my Jeep the personal touch. Removed the Sahara Wrangler Unlimited stickers and replaced them with something a lil more personal. The freedom we enjoy to Jeep in this beautiful country shall always be protected.
ID:	484436   Click image for larger version
ID:	484437   Click image for larger version
ID:	484438   Click image for larger version
Old 08-02-2013, 12:32 PM
  #34128
Mulisha JK's Avatar
Looks great!! I want this system for my rig, but I am afraid I will just tear it off while wheeling.
Old 08-02-2013, 12:45 PM
  #34129
GoinCamando's Avatar
Well said. Excellent personal touch!
Old 08-02-2013, 12:49 PM
  #34130
Kewman33's Avatar
Yes of course, Headlights were easy, except on 2012 drivers side headlight would not seat properly, so just some minor dremel work... fog lights are a lot of work but so worth it.. Black on the yellow looks NICE!
Attachment 484431
