The first number is width and the second is hight so there a little wider but being that there wider they would probably have the same hight as the 75 of the sr-a's. yours are a little wider by a few millimeters
Make sense but when I put one flat on the floor next to the 255, they are the same size. Also if I put the toyo 265 flat on the floor next to my winter Nokian 265, the toyo is about 1cm skinnier.
That's pretty sweet. Especially since I bought my JK used and it didn't even have the cheap little factory plastic tubby cover. So this looks like a good option.
Where did you get? How much? Solid?
Also I added my second front (upper) skid plate. What you mostly see is the upper one, the lower one that angles down and protects the edisco motor I made last week.
Quarter inch steel plate with 4 holes and a bend. Powder coated red. Probably weighs 35 a piece, and it was kind of a trick to get all 3 holes lined up. Had to balance them on my knees and hold them up while dad put the nut on from the other side!
Turned out pretty good though, and I know they won't be going anywhere anytime soon.
Also powder coated my tow hooks red.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=454141"/>
I would think that different brands are subject to very a little bit, there pretty similar that's for sure from what your saying... Ooh well lol
