I bought the kleinn hk7 kit and mounted in a after market storage bin, wasn't happy with the 4:30min fill time on the tank so I added another compressor. I felt so nervous cutting out the old bin, not the sort of thing you want to get wrong.
New Lights
Put a pair of 5" KC Apollo Pro 55 Watt Driving Lights on my bumper bar today. Took them out for a test drive when it got dark and they make a big difference. I have Sylvania Silverstar bulbs in the headlights which are brighter than stock. The KC Lites really light up the sides of the road and in front about 200 yards really nice. I'm satisfied with them. I plan on putting the 6" KC Apollo Pro 100 Watt Long Range Driving Lights on windshield mounts in the near future.
Holy s#%t Batman - that scares me and I'm not the one that cut a hole in my floor. How's it look finished?
Former Member
1 Post
Bought a completely unmolested stock jk 2dr never been off road for 10.5k had a death wobble so swapped ball joints and all better...
Did 37" km2, race line monster bead locks, fox 2.0 reservoir shocks, crowned brake lines 6"+, trimmed fencers, Terraflex 3" springs, sleeved and gusseted front axle, cut and shaved rear frame flipped cross member and gave myself 28" clearance to hitch, started fabbing rear bumper, poly ball joints, relocated exhaust with magnaflow in front of axle with dump, evap relocated, chopped front frame and mounted poison spyder BFH bumper, removed rear lights and flush mounted led lights and plates, HID headlight conversion...ALOT more coming this week....this is all done in the last week..
The Rubi-rails and Sahara steps use the same mount locations, so it's an either or situation. There is also an enhanced version of the Rubi-rail that has tubes welded to push the tub away from rocks & trees. The tube sticks out about 2.5 inches and you can use it as a step. I put skateboard grip tape on mine. But it doesn't keep dirt from hitting the side like the floorboard of the Sahara steps. There are other brands that both protect the tub from hits & have coverage to keep the sides clean from spray and use as a step. But you have to drill into the tub to install nutserts.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=451655"/>
