![](https://www.jk-forum.com/forums/images/ranks/veteran_air_force.png)
Installed a Rugged Ridge Mesh grille insert. It was a pain, as you can see the grille insert was much more curved then the jeep grille and the 2 metal brackets that hold the insert were inconsistent and required some bending as well as the grille.... Once I got it on thought it looked great!
You need to drill 4 holes in the back of the grill and use screws/nuts to hold the brackets. The drilling was easy but I had to muscle the brackets in place because they were not shaped correctly to smoothly fit... Cheap overseas alternative to more expensive stuff I guess
Installed my flush mounted rigid dually led light into my smittybilt XRC rear bumper. Also installed my OTRATTW switches and switch panel flush mounted in front of the cup holders and behind the stick.
That's great! I'm going to install the flush mount in my LoD rear soon as I find a pair at reasonable price. Any issues with the install? What'd you use to cut the bumper?
