Finally, finally got a Teraflex 2.5 coil lift. Been wanting one for years! My Jeep friend and fellow forum member Capt. Scotty helped me install it this weekend. Took a while because of how rusty my Jeep's underside has become over the years.
I will get better pictures when the light allows. It was getting late and we were super tired by the end.
Before:
After:
Before:
After:
Before:
After:
Before:
After:
Before:
After:
Before:
After:
Installed Rigid spot Duallys with Poison Spyder A-Pillar mounts (painted to match)
Fixed Grille Insert (zip tie tabs were coming loose)
Cleaned out interior
Installed Rampage hood locks. Had to take off due to them being too tight. It made hood touch fender (metal on metal).. Fully adjusted. Rampage said every now and then they just don't work on certain JK's (like 3%) Only way to fix was drilling bigger holes and haven't decided to do that yet. There is a write up I found though where someone else had to do the same
I had someone do it. It was fiber glassed into my Dash and the stock radio is sitting on custom mounts behind everything. When you push the top right it releases a magnet and I can slide the iPad right out. Also, my steering wheel controls still work and he put in a bass knob for my sound system. It works great!
